01-20-2012 02:18 PM - edited 07-03-2021 09:25 PM
Can the Flex 7500 control the APs of the 1941w router? I can't seem to find anything definitive on this but it seems odd that I wouldn't be able to control the LWAPP APs of that router when it is specifically designed for the small, remote branches (or in our case retail stores).
Robert
01-20-2012 02:41 PM
of the 1941 has the AP801 embedded, it can run capwap and be controlled by the 5508. Now the 801 is listed as being capable of HREAP so I think it should be possible.
Steve
01-20-2012 02:48 PM
I will agree with Steve... I have a 1941w and it does work in h-reap.
Scott Fella
Sent from my iPhone
01-20-2012 04:37 PM
Yes, that is my dilemma. It does indeed do h-reap and we have a few stores now running that way connected to a 5508. It appears that it SHOULD work, but I can't find anyone that will say it DOES work. I might have to POC this just to find out.
