Flexconnect, branch and central site have same VLAN's
Thomasvdk
Is anyone familiar with a flexconnect deployment where on the central and branch site the same VLAN's are in use?
On both sites the following VLAN's are in place:
VLAN 32 = BYOD
VLAN 31 = USER
VLAN 40 = VOICE
On the branch site I want to deploy Flexconnect. When creating the VLAN mapping in the AP configuration all the VLAN's are instantly assigned. For local branch DHCP ip-helper addresses are configured on the branch switch. When a client connects to the Flexconnect AP it doesn't get an IP address. Suggestions?
Florin Barhala
Level 6
Level 6
Hi Thomas,
On the WLC location, your clients get IP? How did you setup the DHCP Server: on interface level or DHCP Override?
For the FlexConnect sites:
 - enable Vlan Support?
 - specify Native Vlan for the AP mgmt Vlan
 - add Vlan Mapping: Wlan to sites's Vlan
 - finally: configure accordingly the switchport:
 switchport mode trunk
 switchport trunk native vlan ...
 switchport trunk allowed vlan all
Thomasvdk
7 days and still no response, this must be quite unique :)
Have you configured AP management vlan as native vlan on the trunkport where AP connected ? As long as vlan mapping is correct you should able to get IP.
Rasika
*** Pls rate all useful responses ****
Thanks all..seems to work now. Was a local issue with BYOD devices
Florin Barhala
Level 6
Level 6
Hi Thomas,
