Flexconnect Groups and VLAN templates
StuartR
I'm looking for some information or a document regarding the use of Flexconnect groups and Fleconnect VLAN templates and Cisco ISE.
Thanks in advance
Stuart
Moin Ilyas
Level 4
Level 4
http://www.cisco.com/c/en/us/td/docs/wireless/controller/8-0/configuration-guide/b_cg80/b_cg80_chapter_010001010.html
http://www.cisco.com/c/en/us/td/docs/wireless/ncs/1-1/configuration/guide/NCS11cg/temp.html#wp1213230
Hi Moin,
Thanks for these links, I've seen these before, but they're missing info on usage of Flexconnect VLAN templates.
Updated : I eventually found this doc which explains it quite well : http://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-1/Flex-7500/Flex_7500_DG.html
Stuart
Garry Cross
Well it has been almost 4 years since this and I could not find info on the usage of these templates in the latest guide.
Using the Flex 7500 Wireless Branch Controller Deployment Guide seems to be the only document that discusses this.
