12-11-2003 10:56 AM - edited 07-04-2021 09:13 AM
Does anyone know if it is possible to force a users homepage/IE to go to a certain site no matter what they have set? It is a public access scenario and all they want to do is display an internet disclaimer. I would be using an AP1100 and possibly a PIX firewall.
Any ideas? I'm trying to do it without having to put BBSM at every location.
ryan
Solved! Go to Solution.
12-12-2003 01:41 AM
Hi ryan,
AFAIK neither AP nor PIX are able to do that.
The best soltution would be BBSM for small businesses or CSG or SSG for big environments
There you have the possibility to redirect users to a login page or any other page you`d like.
Also you can do this via some transparent web proxy , like squid.
If you`d like to build public WLAN solutions , have a look at SSG and CSG , they are really powerful and new features will come out for PWLAN. (SSG + AZR on same box)
regards
Michael
12-12-2003 01:41 AM
Hi ryan,
regards
Michael
12-12-2003 06:40 AM
Michael, do you know if you can use the SSG feature set in a router just by itself to redirect to a webpage on the internet as their homepage before they surf? I don't even need it to do any authentication.
ryan
12-12-2003 08:10 AM
Hi ryan,
yes you can use SSG for redicting users without doing any authentication, either user SSG redirect for initial captivation or advertisement captivation.
Have a look here
however, SSG is only available on some plattforms, and as far as I understand your need, you just have small hotspots which need initial redirection. I think the smallest plattform supporting SSG feature set is the C2651XM , which already could be a overkill in your solution ...
regards
Michael
