FRA not covering 2.4GHZ
syedimteyazahmad
Beginner
Beginner
Hi team,
My AP is not seeing 2.4GHz signal but still its both slot working on 5 GHz. Can you please help to resolve issue. Its happening to multiple AP. Can we disable FRA?
2 Accepted Solutions
Haydn Andrews
VIP Engager VIP Engager
VIP Engager
You can disable FRA by going:
Wireless>Advanced>RF Management> Flexible Radio Assignment> Disable
You then might need to run this CLI command if the APs still do not change the XOR radio to 2.4
config advanced fra revert all auto
If you have manually configured the setting on any of the XOR radios then use this command
config advanced fra revert auto-only auto
*****Help out other by using the rating system and marking answered questions as "Answered"*****
Leo Laohoo
VIP Community Legend VIP Community Legend
You can disable FRA globally or individually (or per AP basis).
12 Replies 12
Haydn Andrews
VIP Engager
Thanks for the post
Hi @Haydn Andrews
Can you also please tell me the command to enable FRA To be  operated as manual from auto.
There isnt a option to enable FRA as manual
What you can do is under Wireless>Accesspoints> Dual-Band Radios
you can configure each AP Radio Role Assignment to manual, then select client serving or monitor and select the band.
Hi @Haydn Andrews
We did disable FRA and AP is seen with 2.4GHz but still no wlan visible on 2.4Ghz. Any specific reason
Check the AP if the micro radio has switched to 5.0 Ghz or not.
HI @Leo Laohoo
How to check micro radio.
Monitor > Dual-Band Radios > Detail
Find the AP, go to the right-hands side and choose "Configure".
Under "Radio Role Assignment", what does it say there?
Hi @Leo Laohoo
Its showing radio role as auto , but also seeing client serving is marked but its graded. I am attaching picture.
Did you try to reboot the AP? You should try to move the ap to a different ap group and then back to the ap group you want the ap to be in. The AP isn’t taking the command to enable the radio.
-Scott
I think you have to toggle the radio up and down. I remember an issue with that, you can try toggling the radio up and down or reset the AP.
-Scott
Leo Laohoo
Recognize Your Peers
