Frequent wireless connection and disconnection
jgrement.
Some one post this, and I'm having the exactly same issue
I am running 5508 controller with version 7.0 and 1142N access points.. I am facing a problem on user connectivity.
Wireless Users are getting frequent connection and disconnection. These users are not getting connected to the access point nearby although this access point is up and running. I have tried reducing the power level, configured the AP after resetting it. But nothing helps.
Tomorrow I will debug one client and paste some logs.
What information do I need to attach?
Thanks!!
Kayle Miller
Level 7
Level 7
What type of security and encryption are the ssid's using? What client or supplicant are you using?
Hi, thanks now i have a SR, when i get the answer i Will post
