Global Multicast Mode but exclude Guest WLAN
emily00001
I'm on a 2504 and had Global Multicast Mode set to on. This worked on all the controllers WLANs. On the guest WLAN I enabled P2P blocking but noted that the multicast was still active there. I tried to disable the Global Multicast Mode on the controller and use Multicast VLAN Feature on the WLANs where I wanted multicast to work but that apparently doesn't work when global multicast mode isn't checked.
What do I do to have multicast on for only some of my WLANs? Is it at all possible?
Rasika Nayanajith
This is expected behavior. You cannot control multicast traffic using P2P blocking feature. Pls have a look at "restrictions for peer-to-peer blocking" section of below document
http://www.cisco.com/c/en/us/td/docs/wireless/controller/8-2/config-guide/b_cg82/b_cg82_chapter_01010001.html
from WLC level, I do not think there is a solution. But at the switch level you can disable PIM on the interface defined for guest wireless users. That should helps
Rasika
*** Pls rate all useful responses ***
Rasika Nayanajith
Rasika
Ok, thanks for the advice.
