Group APs by which SSID to broadcast
pganet123
Hi all
Now, I have searched for this for several days - I want to determine which APs show certain SSIDs. There must be a smart way to do that beside using the override function on 100 different APs.
I have WLC 4404 and 1131AG-E-K9 LAPs.
Any suggestions?
Thanks in advance.
Peter
grzegorz.ciolek
Yes there is... but in 5.2.x version. Instead of WLAN override you are grouping AP. I think that below 5.2 you have only WALN Override.
Chers
Greg
Thank you Greg.
Im running 4.2.112.0 right now, so must upgrade in future.
Rob Huffman
Hi Peter,
The most popular way to mitigate the problem of having to access each AP individually (when using WLAN Override) is to use WCS Templates for common requirement AP's. This way the WLAN Override function can be applied at the Template level and then pushed out to the various groups.
http://www.cisco.com/en/US/docs/wireless/wcs/4.0/configuration/guide/wcstemp.html#wp1072198
Hope this helps!
Rob
Well, it is certainly the most expensive way. I have no need of the Wireless Control System.
I will just upgrade my controller to ver. 5.2 and you can consider this topic as solved.
