Guest Wireless captive portal system
eit-homing
Any good wireless captive portal sytem that you guys recommend for guest wireless network? Does Cisco have it solution? Is it the WLC? Thanks.
diro
I always advice my clients to use cisco airspace wlc for this feature (it's called web authentication). You could also use zonecd.
nickle
I don't know if you are still looking for additions to your guest wireless system but I have put together some simple PHP code that helps automate the guest user creation.  Find the code here: https://sourceforge.net/projects/simple-swag/  The original intention of the code was a simple way for administrators to provide simple Lobby Ambassidor like function to a simple web interface and then provide customized guest user instruction page.  In the background it uses ssh to talk to the controller and setup the account. Its written in PHP so feel free to try your hand at it.
thanx for the code )
George Stefanick
If you have a NON-WLC solution such as Autonomous you could do a 3rd party box like
http://www.nomadix.com/.
These work very well... And there are others ..
