HA Beetwen a WLC 5508 and WLC 5520
molinait
Hi everyone!
It is possible to setup a HA between a WLC 5508 and WLC 5520 the 5508 as primary?
Thanks!
@molinait
I never try before, but according to this link  your 5508 will be in maintenance mode.
***Please rate the answer if this information was useful***
**Por favor si la información fue util marca esta respuesta como correcta**
*Tu reconocimiento nos alienta a seguir participando en los foros *
Espero que la información haya sido útil y si no tienes más preguntas recuerda cerrar el topic, seleccionando la respuesta como "Respuesta correcta"
7 Replies 7
Jurgens L
Level 3
Level 3
You won't be able to run N:N switchful state over (SSO), however, you should be able to run N+1 provided both WLC's run on the same software.
One thing to take note though, the 5508 only support up to version 8.5.xxx, and also just take into account the software you will use on how compatible it will be with the access points in the environment.
Ok, so we won´t be able to setup SSO HA using the redundant port if the WLC are different like this case?
Thanks!
@molinait
Hi @molinait
Same limitation for 8.8 so, I think is not a good idea try to pairing
Here the link for 8.8
Thank you all for the replies!!
That link applies for SSO high availability only.
To the original question, if you want the 5508 to be the primary wlc, you can run an N+1 HA solution, permitted both controllers are running the same version 8.5 code and not any other version higher as the 5508 doesn't support any higher software version from 8.6 onwards.
SSO requirement is that the wlc are the same model and on the same code. In your scenario, you will not be able to implement SSO.
-Scott
