Amr_Elsherif
Beginner
Handheld WiFi connectivity issue with AP 1852i
I have Cisco AP 1852i operating in mobility express mode its image is 8.5.151 which the recommended version recently.
Handheld mode is MC92-Zebra with windows mobile 6.5 the issue is the handheld can't connect to the SSID created on the Cisco AP, so what could be the issue?
1 REPLY 1
pieterh
VIP Collaborator
you supply very little information! a lot of things can be the cause of this.
you should gather some logs on the hand-held and on the AP to find some clues.
but mostly you need to look for security and compatibility.
because this is an old device first check if the both speak the same language (use the same wi-fi protocols.
I guess the hand-held supports the 802.11b protocol (maybe b/g)
and the AP speaks 802.11 n/ac -> those will not be compatible
Create
Recognize Your Peers
Content for Community-Ad
