Hardwired cbw140ac AP slow - max 115 Mbps
I have a hardwired cisco cbw140ac AP to Gb linksys router port 30 ft Cat 5e cable length. Wifi speeds at 5Ghz wifi next to linksys router are 350 Mbps using the router SSID,   Wifi speed next to cbw140ac AP using the AP SSID is only 110 Mbps.
Anyone have any ideas what is causing the lower speed from the cisco AP?
computer is 802.11 ac MacBook PRO which has max wifi around 400 Mbps.
1 REPLY 1
patoberli
VIP Advisor
How is the 5 GHz configured? Have you enabled 80 MHz wide channels?
Create
Recognize Your Peers
Content for Community-Ad
