Heat Mapping with WCS
Atif Raees
Can anybody suggest, wether Heat Maps can be generated via WCS BAse license only or do i need WCS with Plus lic and Location Services Appliance.
Atif
George Stefanick
Heat maps are generated in either base or PLUS. Plus allows you to track devices.
Piggy Backing on George's reply:
  WCS shows an RF prediciton of coverage with all licenses.  So what you see may not be what you get, but it will be darn close.
NCS is supposed to have 'real time' coverage from the AP.  You can get a 30 day trial license for the VM image of NCS, that will monitor 10 devices.
HTH,
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
