Help! Can't get association
russell-r
all:
i have an access point that sits 75 ft away from a wgb. the problem is the wall between them... i can't seem to get a signal to the wgb through the wall. if i move from behind the wall i can get access... is the ANYTHING i can do to penetrate the wall?
thanks
wong34539
Level 6
Level 6
I guess the only option is to have another AP in the room, I don't think there is any other work around.
