Help enabling 5g radio on AIR-CAP2702I-A-K9
dd2
I have a air-cap-2702I-A-K9, the 2.4ghz radio is enabled and functioning well but I can't enable the 5ghz radio in the GUI. This ap has been converted to Autonomous mode. I was reading about priming the ap but it only applied to UX models. Any help would be appreciated.
"I have a air-cap-2702I-A-K9, the 2.4ghz radio is enabled and functioning well but I can't enable the 5ghz radio in the GUI."
Did you try it via CLI ? It should work
Rasika
Yes I was able to enable the radio through CLI, however I was unable to join the broadcasted 5ghz network. It shows up on my wifi list with correct SSID but when I tap on it to join nothing happens. I P/C both my phone and AP samething. In the GUI it showed the antenna is enable but under settings its still blank no info populates.
Try another reboot of the AP.
Does the AP get enough power?
Which channel and channel width do you have chosen?
