Help Upgrading IOS on 1200 AP Using CLI & TFTP
sabrautigam
I am not to familiar using TFTP to upgrade the IOS on the Aironet access points as I have always done it via the GUI. I have Solarwinds running with my IOS in the root dir and the AP connected via console cable. Everytime I attempt to upgrade via the CLI I am getting a time out error message while nothing shows up in the log. Below is the command I am issuing along with the error message I get. Any help is greatly appreciated. Thanks in advance
ap#archive download-sw /overwrite tftp://10.10.10.8/c:/TFTP-Root/c1200-k9w7-tar.123-8.JA.tar
examining image...
%Error opening tftp://10.10.10.8/c:/TFTP-Root/c1200-k9w7-tar.123-8.JA.tar (Timed
out)
ERROR: Failed to open archive file tftp://10.10.10.8/c:/TFTP-Root/c1200-k9w7-tar
.123-8.JA.tar
8 Replies 8
scottmac
Level 10
Level 10
If you designate the root directory in SolarWinds, you shouldn't specify the directory path in the tftp statement.
So, in SolarWinds, if you have already pointed to /TFTP-Root as your directory, you would then request tftp://10.10.10.8/c1200-k9w7-tar.123-8.JA.tar
Good Luck
Scott
Scott, thanks for replying. I tried what you recommended and I received the same time out error. It is rather late here so I will be back to the drawing board tomorrow. I am open to any other suggestions. Thanks again.
Steve
You have to ensure the case of the filename. It is case sensitive and the root of the tftp server is not same as root in TFTP command in AP.
Hope this helps.
Jack,
I tried what you posted and I was able to make some progress. It actually showed up on the log but this time it gave me the error listed below. I checked windows firewall and disabled the firewall on my 871 router in the event I was blocked. Any suggestions?
%Error opening tftp://10.10.10.8/c:/tftp-root/c1200-k9w7-tar.123-8.JA.tar (Permi
ssion denied)
ERROR: Failed to open archive file tftp://10.10.10.8/c:/tftp-root/c1200-k9w7-tar
.123-8.JA.tar
logfile error from solarwinds
8/17/2006 18:08 :TFTP Server Error: Invalid access to c:\tftp-root\c1200-k9w7-tar.123-8.JA.tar from 10.10.10.6
Stephen Rodriguez
Follow the directions listed here.
http://www.cisco.com/univercd/cc/td/doc/product/wireless/airo1200/accsspts/b1238ja/1238jasc/s38trb.htm#wp1048378
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Thanks for your posts guys. I will give it a shot when I get back to the office this evening. I will post an update after my failure or success. Thanks again I appreciate all your help.
Please remove the C:/TFTP-root as mentioned by Scott and set the C:/TFTP-root as root in your TFTP server.
i.e.
archive download-sw /overwrite tftp://10.10.10.8/c1200-k9w7-tar.123-8.JA.tar
It finally worked, thank you so much for all your help guys I really appreciate it. You have now created some work for me as I have to get about 20 of these units done by Monday morning :)
