High RTT and packet Loss
cnrs-dsi
Beginner
Beginner
We use a WLC 4402 and 11 AP 1250.
My clients are Windows seven.
When they are connected to wireless, all my clients have randomly RTT peaks and packets Loss (2% average).
I enable link latency between AP and WLC. Max RTT are from 20 to 64ms.
Any idea ?
Réponse de 172.16.242.9 : octets=32 temps=3 ms TTL=64
Réponse de 172.16.242.9 : octets=32 temps=5 ms TTL=64
Délai d'attente de la demande dépassé.
Réponse de 172.16.242.9 : octets=32 temps=446 ms TTL=64
Réponse de 172.16.242.9 : octets=32 temps=1 ms TTL=64
Réponse de 172.16.242.9 : octets=32 temps=8 ms TTL=64
Réponse de 172.16.242.9 : octets=32 temps=50 ms TTL=64
Réponse de 172.16.242.9 : octets=32 temps=93 ms TTL=64
Réponse de 172.16.242.9 : octets=32 temps=4 ms TTL=64
Réponse de 172.16.242.9 : octets=32 temps=2 ms TTL=64
Normally you should not have timeouts at this signal strength. What are you trying to ping by the way ?
any server on the LAN ? If its on the LAN and still getting timeouts, guess you should look at any interference sources which are operating on the same channel and eating up duty cycle.
regards
Joe
8 Replies 8
Stephen Rodriguez
Honestly, to be expected.  Wireless is a shared media, so if client A is talkling, client B can not.  This is going to have some inherent loss, due to this.
Cheers,
Steve
If  this helps you and/or answers your question please mark the question as "answered" and/or rate it, so other users can easily find it.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
wireless wlc
Beginner
Beginner
At what signal strengths are you seeing these losses ?
regards
Joe
91% (-54dB)
I'am really close from the AP.
Do you have power save mode enabled on your client ? Is so, disable and you should see some improvment. Although, look at what you posted this is normal behavor..
regards
Joe
Perhaps the cleint is roaming ... You will lose a ping or two ...
I try to ping a local wlc interface.
I have manually changed channels. Activate WMM on clients and it's look better.
Thanks for your help.
Scott Fella
Hall of Fame Guru Hall of Fame Guru
Hall of Fame Guru
Its really normal.. Here is a screen shot from my iPhone.
-Scott
Recognize Your Peers
