How do I see what speed a pair of 1410 bridges has negotiated to
tdennehy
Beginner
Beginner
I'm working on a pair of 1410 bridges and I see in the GUI that both interfaces are up, 100mb/s and 54 mb/s.  My guess is these are the interface speeds and not the negotiated speed of the WLAN Interface.
Anyone know how I can find the actual negotiated speed?
Many thanks in advance!
ok, once you have the mac address do a
show dot11 association < mac address > you'll get more detailed information.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Stephen Rodriguez
I'd go with a show dot11 association.
HTH,
Steve
HTH,
Steve
Yeah, tried that... but it is not in the output.  I can't seem to find that information anywhere... but then again, first time working on the 1410s.
HTH,
Steve
HTH,
Steve
Roger that.  Just as I expected... SNR is 5dB.
Current Rate      : 9.0                Capability       : WMM ShortHdr
Supported Rates   : 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
Voice Rates       : disabled           Bandwidth        : 20 MHz
Signal Strength   : -86  dBm           Connected for    : 17 seconds
Signal to Noise   : 5   dB            Activity Timeout : 30 seconds
Recognize Your Peers
