Showing results forĀ
Search instead forĀ
Did you mean:Ā
How often does controllers try and establish connection in a mobility Group?
salamislimy
HI
I have a pair of controllers connecting to a pair of mobility anchors.
While one controller establishes connection to both controllers, the second has both controller and path down for both anchors.
Checked the firewall and found incomplete arp entries for the second controller.
Do we know how often do the controllers try and establish a connection to the anchors?
2 Accepted Solutions
Scott Fella
Mobility in general happens is constant. If there is any interruptions, the tunnel goes down. This is a two way communication between the controllers.
-Scott
Exactly - it will come up almost immediately once you fix the config and/or network connectivity.
Scott Fella
-Scott
