How to authenticate Lobby Admin through Active Directory
PRASAD BAIT
We want to configure WLC in such way that user with Lobby Admin privileges should authenticate through AD.
In other words , is there a way to configure a user account in AD which is used by the WLC for authentication that has only the privileges of Lobby admin (managing guest users)?
Prasad
Sandeep Choudhary
As per my knowledge it is not possible because Lobby Admin try to access the WLC as management user, that is why someone needs to tell the WLC what privilege does that user account will have.
I think this is only can be done RADIUS server.
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wlan-security/97073-auth-lobbyadmin-radius.html
Dont forget to rate helpful posts
