How to Change Radio Role to Client Serving for a C9130AXI-B WAP
CWoods
I have a C9130AXI-B / 802.11bg:-A 802.11a:-B not broadcasting 2.4GHz radio signal. I checked my other C9130AXI-B WAPs configuration against the config of the device not broadcasting. Its Radio Role is set to Monitor and the others are set to Client-Serving. How can I change the radio role from monitor to client serving for a Cisco C9130AXI-B wireless access point?
5 Replies 5
 You can use this
"ap name apname dot11 |24ghz |5ghz |slot <slot ID> radiorole |auto |manual |monitor |client-serving
Thank you for the info. Im new to the IT field. Learning on the job. I cant seem to get the command "config t" to work. My config options are config
ap    AP configuration
boot    Set boot parameters
cts    Configure cts debug parameters
mesh    Configure mesh options
security    security information
Which option do I choose? Neither seem to work. I really appreciate any assistance you can offer.
ap ? (what options you see ) - may be i was thinking cat 9100 may have different format (need to check command syntax)
BB
auxiliary-client      Configure auxiliary-client interface VLAN
        vlan                     Configure Vlan for interface
client-trace           Configure Client Trace
        address                Configure Clients to trace
        all-clients              Trace ALL Clients
        clear                     Clear Client Trace event log
        counter                 Configure Trace counters
        filter                      Set Filters for Client Trace
        output                   Configure Trace Output
        start                      Start Client Trace
        stop                      Stop Client Trace
cloud                    Configure cloud servers
       address                   3cloud server address
tls                         Configure TLS tunnel
       address                   tls gateway address
       auth-method            type of authentication
balaji.bandi
Before changing - Make sure you are aware of the setup, sometimes as part of the design some AP setup as monitors the wireless in the environment. If that is not the case you can change as suggested.
BB
