HOW TO CONFIGURE 1131AG WITH CONSOLE
isaaco001
Level 3
Level 3
Dear Community,
I am trying to change an 1131AG LWAPP to Autonomous. I have connected my console cable to the console port and with usb connected to the computer port.The access point is being powered by POE. However, i am not seeing anything on the console screen.How can i get console feed?Must the pc connection be connected with  DB9 and the LWAPP powered by cable for this to work?
Thanks.
Isaac.
2 Accepted Solutions
Scott Fella
Here is a link to review:
https://supportforums.cisco.com/document/12341/how-console-cisco-aironet-access-points-and-bridges
Also the issue can be with the serial to USB adapter you are using.  Even though it might work on switches and routers, might not work well on AP's.
I have used this:
https://www.get-console.com/shop/en/usb-to-serial-cables/57-usb-serial-cable-rj45-180cm.html
-Scott
-Scott
No enamble mode on lightweight AP's.
-Scott
-Scott
7 Replies 7
Scott Fella
I have used this:
-Scott
-Scott
Hi Scott,
Thanks for the advice,I removed the usb and connected the console to DB9 port.However, i have ran into another issue.I cannot get passed enable  password after reset.The default should be Cisco but this is not working.Please advice.
Isaac.
Factory default the AP. Here is a link but you can probably find videos also.
http://blogs.scansource.com/cisco-ap1260-access-point-how-to-reset-defaults/
All AP's use the same method.
-Scott
-Scott
Scott,
I believe i have set the 1131 to factory by pressing the mode button/reset button  until the led turns red and waiting until it(cli)tells me "waiting to release button in console".However, i am prompted for password when trying to get to privileged exec mode but "Cisco" default password isn't working.I am still troubleshooting the issue anyway.I will check again my steps thoroughly in the documentation you referenced.Thanks once again.
Isaac.
-Scott
-Scott
Scott,
You were right,the mode button works(1130).Just ran into some trouble here an there. Thanks a lot.
Isaac.
Glad to help. Just keep in mind that holding the mode for 10 seconds will factory reset the AP and holding it for 30 seconds will boot the AP in ROMMON mode.
-Scott
-Scott
