08-06-2014 06:29 AM - edited 07-05-2021 01:19 AM
How to configure Catalyst 2960-s switch to allow communication between two Wireless Clients on two different VLANs. Couldn't able to do data transfer between two wireless clients.
Test setup:
Test setup includes Cisco 1240 AP, Catalyst 2960-s switch and Cisco ACS for EAP-FAST authentication.
Cisco 1240 AP and Cisco ACS Configuration:
1.AP IP Address : 192.168.6.3.
2.Configured two SSIDs with two different VLANs (VLAN 2: TKIP, VLAN3: CCMP) and configured the VLAN1 as native VLAN.
3.Connected the Cisco ACS to the Cisco 1240 AP and configured for EAP-FAST authentication.
Catalyst 2960-s switch Configuration:
Switch#configure terminal
Switch<config>#interface fastethernet 0/1
Switch<config-if>#switchport mode trunk
Switch<config-if>#switchport trunk native vlan 1
Switch<config-if>#switchport trunk allowed vlan add 1,2,3
Switch<config-if>#switchport nonegotiate
Solved! Go to Solution.
08-06-2014 01:18 PM
Layer 3 so the clients are able to route between each other. the 2960 is a layer 2 switch, since you are doing inter-VLAN you need some L3 in there.
HTH,
Steve
08-06-2014 07:00 AM
What are you using for your L3 gateway? if you are going cross VLAN you have to have a L3 gateway configured
HTH,
Steve
08-06-2014 07:08 AM
Thanks Steve for your reply.
You mean L3 gateway to be configured on switch ?
Harsha
08-06-2014 01:18 PM
HTH,
Steve
