yong1794
Beginner
How to configure two br1400s with EAP?
I like to configuring two BR1400s EAP authentication and Dynamic 128bit WEP(or TKIP) with ACS3.3 authentication server.
I think the root bridge could be have EAP seting(RADIUS server, shared secret ket, encrytion an so on) and non root brighe could be set like wlan client (set only ID/Passwords) without EAP seting.
Is this right?
1 REPLY 1
mark.stephens
Beginner
You need to point both the root and the non-root towards the ACS server using IP address and port 1812 using eap settings and then specify a eap username and password under the ssid. Please see below partial config from my non-root which is using Cisco LEAP:
ssid XXXX
authentication network-eap eap_methods1
authentication client username XXXXXXXX password XXXXXXXXXX
station-role non-root
radius-server host x.x.x.x auth-port 1812 acct-port 1813 key xxxxxxxxx
radius-server vsa send accounting
Hope this is of some help!
Mark
Create
Recognize Your Peers
Content for Community-Ad
