How to enable 802.11n in WLC 2106???
rguzman.plannet
I had already posted for help with this issue but I could not find that topic in the forums.
So what I need is to eable the 802.11n service in my WLC sice 802.11g is the one working.
Regards!
Tiago Antunes
I guess this is the document you were looking for...
Configure 802.11n on the WLC:
http://www.cisco.com/en/US/products/ps6366/products_tech_note09186a0080a3443f.shtml.
HTH,
Tiago
If  this helps you and/or answers your question please mark the question as  "answered" and/or rate it, so other users can easily find it.
Tiago is correct but reading your question I understand you maybe want to activate the radio 802.11a/n which shows as down, right ?
If you read on the right it says "regulatory domain not supporteD".
What AP part number do you exactly have ? And to what country to you have configured your WLC ?
Nicolas
Don't forget to rate answers that you find useful
Hi Nico,
(Cisco Controller) >show country
Configured Country............................. MX  - Mexico
Configured Country Codes
        MX  - Mexico.................................... 802.11a / 802.11b / 802.11g
AP Model
1- AIR-AP1141N-A-K9
(I am trying to convert it to LWAPP but cannot add it to the WLC yet, I have annother opened discussion for this case)
But also I want to enable 802.11a in the rest of APs which are 1131 that were converted from Stand Alone to LWAPP.
1141 means that they only have one radio (802.11/b/g/n) so you're out of luck for those ones.
The 1131, contrary to what they part number indicate should have 2 radios (they should be named 1132 but ...).
Did you go to "wireless"->802.11a"->network-> enable ?
Nicolas
