06-12-2017 12:59 PM - edited 07-05-2021 07:11 AM
I have 282 access points on our wireless network which has a Cisco 5760 controller. All the APs are capable of 802.11a/n/ac and 802.11b/g/n. Recently I noticed that one access point is only using the b/g/n radio. I would like to know how I can easily find which AP has the missing a/n/ac radio.
Access Point Summary
Total | Up | Down | |
802.11a/n/ac | 281 | 281 | 0 |
802.11b/g/n | 282 | 282 | 0 |
All APs | 282 | 282 | 0 |
06-15-2017 02:01 PM
Hi Craig,
You should be able to find it easily. Try below CLI command & see
5760#show ap dot11 5ghz summary | in Down
Rasika
*** Pls rate all useful responses ***
06-16-2017 11:22 AM
Hi Rasika,
Thank you for your suggestion. Unfortunately, this does not work for me because the 5GHz radio seems to be completely dead. Subsequently, I was able to find the AP in question and the 5GHz radio does not even show up as an interface to configure any more. It's like its not even there.
