How to have H-REAP broadcast only specific locally switched SSID's?
msmith
I'm new to this H-REAP configuration, but in the main office we have about 6 WLAN's.  I have a remote office which I want to have 2 new WLAN's and have them switched locally.  How can I only have the H-REAP AP's at this site only broadcast those 2 SSID's vs all 8?  I haven't really read anything about using AP Group VLAN's with H-REAP or know if that's even possible, but is this a possibility and if no,t what would you recommend?
Thanks for the help!
George Stefanick
I havent done WLAN override over HREAP before, but i dont think why it wouldnt work. iIf you only want to "support" certain SSIDs WLAN override will allow you to shape that ...
Here is a link for further reading
http://74.125.95.132/search?q=cache:RX3jjIk_EzcJ:www.perihel.at/wlan/wlan-wlc.html+cisco+wlc+hreap+wlan+override&cd=6&hl=en&ct=clnk&gl=us
weterry
Level 4
Level 4
I've definitely seen/used AP Groups to do just what you're asking.
Configuring AP Groups (5.2 configuration guide): http://www.cisco.com/en/US/docs/wireless/controller/5.2/configuration/guide/c52wlan.html#wp1128591
Keep in mind that WLAN Override as part of "AP Groups" is only in 5.2+
Prior to that, WLAN Override is enabled per AP, per Radio.
Great, I will check this out.  Thanks for the help.
I may create another topic - but here it goes...
I've decided to try to use an existing WLAN in the H-REAP config...
-I've joined the AP to the remote controller, assigned it an IP, put it in H-REAP mode.
-I chose a WLAN, enabled local switching
-I went into the AP, configured the native VLAN, however, I CAN NOT change the vlan of the WLAN listed.  It always goes back to default.
I verified the vlan exists on the switch, is routable, etc, the switch port is a member of that vlan, it is set as a trunk w/ 802.1q, etc.
Any ideas on what would cause this?
I am SOO close   Thanks!
