how to map wireless device with vlan on wlc
WINCis
hi everyone
I have wlc and radiud set up. on the campus network. once the client connect to the wifi. the radius will classified group type of user, then assign them an vlan. this time wlc will receive device's mac and vlan id. my question is how the wlc map client device with vlan?
balaji.bandi
you can Look BYOD kind of setup with CoA based in the user.
check below guide for reference :
https://community.cisco.com/t5/security-knowledge-base/cisco-ise-byod-prescriptive-deployment-guide/ta-p/3641867
Depends on the WLC and AP you using you can refer that product configuration guide.
BB
marce1000
 - As other poster noted ; controller model was not included ; check this document for 9800 platforms :
                 https://www.cisco.com/c/en/us/support/docs/wireless-mobility/wlan-security/217043-configure-dynamic-vlan-assignment-with-c.html
 M.
