08-26-2017 10:56 AM - edited 07-05-2021 07:35 AM
we have more than 300 AP groups created in Wireless controller and want to add same SSID in all AP groups is there any shortest way and/or single command to achieve this tasks, really appreiciate for quick support. thanks.
Solved! Go to Solution.
08-26-2017 04:50 PM
As long as SSID is created on your WLC, I would use below CLI command to derive requried config lines to push it to your AP gorups. Once prepared, you can apply it via WLC CLI
config wlan apgroup interface-mapping add <AP_Group_Name> <WLAN_ID> <Dynamic_Int_Name>
Rasika
*** Pls rate all useful responses ***
08-26-2017 04:50 PM
Rasika
04-10-2018 10:29 PM
I did not find any command to push SSID in all AP GROUP.
Rasika,
you see anything regarding this.
Please post here.
04-10-2018 10:40 PM
