How To Set Default Speakerphone Volume cisco 7821
SpeakIT
My company is having a problem with users turning down the Speaker volume on the phone(7281) and missing on broadcast announcements. Is there a way to lock the phone speaker volume to max.
patoberli
You landed in the Wireless (Accesspoints, Controllers, …) forum, I think your question would be suited for the phone forums.
In any case, you really want to have your phones to always ring at the max volume when somebody calls a user?!?
Maybe there is even a broadcast function that raises the volume to max, but I'm no phone specialist.
Thanks, @patoberli, I will move it to the phone forum.
The ring volume feature does not affect broadcast announcements. I tested and found that it is the loudspeaker volume that affects announcements. I already found a configuration menu for setting the maximum ring volume. I need to find a way to set the same for speaker volume.
rosapamela
I don't know if your able to assist me or not but I have a cisco office phone module number CP-8811 and this phone is the only phone that wont let me adjust the volume when a incoming call is made. is there anyway I can by pass it for I am able to adjust the phone ringer volume when I have incoming calls? it stays on one ringer volume and it wont move from that one set.
