ā01-10-2017 02:47 AM - edited ā07-05-2021 06:20 AM
Anybody have a good idea how to turn of radio interface 802.11b/g/n on AIR-CAP2702I-E-K9.
I cant find the command in the CLI or in Cisco Prime.
Fredrik
Solved! Go to Solution.
ā01-10-2017 03:51 AM
use these command:
AP001#conf t
Enter configuration commands, one per line. End with CNTL/Z.
AP001(config)#interface dot11Radio 1
AP001(config-if)#shutdown
AP001#conf t
AP001(config)#interface dot11Radio 0
Dont forget to rate helpful posts
ā01-10-2017 03:49 AM
Have you tried SHUTDOWN command on specific interface ?
Or if you use WLC then try login to web management and go to WIRELESS tab, then RADIOS menu, 802.11b/g/n menu, choose some AP and click on configure.
Change admin status to DISABLE
use these command:
AP001#conf t
AP001#conf t
ā01-10-2017 05:00 AM
thanks. Strange this is that in the prime it still says its enable. but the interface is down in the AP.
