09-01-2011 07:00 AM - edited 07-03-2021 08:39 PM
Good monrng all.
I have seen this not once but now twice in less than a week.
I have several remote offices up on HREAP. The configs were done on the WiSM using 7.0.116.0 code. the configs were saved and the sup720 in the 6500 was upgraded and rebooted. The native vlan for HREAP is vlan798 the office vlan is vlan 1. After the reboot of the sup and you look into the WiSM the native vlan is still 798 but now the office vlan is also 798.
The APs we are using are the 1142
09-01-2011 11:58 AM
That is really strange.
There is something about vlan 1 that is ringing a bell... do you have any other vlans on that switch, or just 798 and 1?
Out of curiosity, what is your native vlan?
09-02-2011 04:35 AM
The earlier discussion was that native couldn't be vlan 1
My native vlan is 798, This is a vlan that we use for all Access points on the campus as well as for hreap off the campus.
Another note on this that I thought was odd.
If I fail the AP's to thier backup controller the same thing happens. The ap is primary on Building one Distribution A wism side A and fails to building two Distribution A wism side A. Once the AP comes up the native is 798 but the vlan mapping to the office SSID changed to match the native 798 instead of remaining as vlan 1.
Manual intervention really isnot an option here every time an AP moves.
09-02-2011 03:42 PM
Hi Michael,
Would you be able to share the switch side of the equation? Can you show the port config and port-channel config that connect your wism and 6500?
What code version are you running on wism and switch?
09-02-2011 03:47 PM
One more multipart question:
The switchports that the HREAP access points are connected to, how are they configured? Are the access points in local switching HREAP or central switching ?
09-06-2011 05:38 AM
I'm using local switching for the remote office users.
Office Switch port config
AP Port:
interface FastEthernet0/1
description HREAP Access-Point
switchport trunk native vlan 798
switchport trunk allowed vlan 1,798
switchport mode trunk
no logging event link-status
no snmp trap link-status
spanning-tree portfast
interface FastEthernet0/24
description Router Port
duplex full
speed 100
ip dhcp snooping trust
Office Router
Cisco IOS Software, 2800 Software (C2800NM-IPBASEK9-M), Version 12.4(24)T3, RELEASE SOFTWARE (fc2)
ip dhcp excluded-address 10.200.1.9
ip dhcp pool AccessPoint
network 10.200.1.8 255.255.255.248
dns-server 1xx.xx.xxx.10 1xx.xx.xxx.135
default-router 10.200.1.9
lease 0 0 30
update arp
interface FastEthernet0/0.1
encapsulation dot1Q 1 native
ip dhcp relay information trusted
ip address 172.16.81.129 255.255.255.192 secondary
ip address 1XX.33.81.129 255.255.255.224
ip access-group OFFICE out
ip helper-address 1xx.33.250.10
ip helper-address 1xx.33.189.135
no ip redirects
no ip unreachables
interface FastEthernet0/0.798
encapsulation dot1Q 798
ip address 10.200.1.9 255.255.255.248
no ip redirects
no ip unreachables
09-06-2011 05:32 AM
With the current version of code on the 6500 I can no longer see the interfaces on the modules. AP's in the facility are functional
sh mod 9
#sh run mod 9
Building configuration...
Current configuration : 5 bytes
end
#sh mod 9
Mod Ports Card Type Model Serial No.
9 10 WiSM WLAN Service Module WS-SVC-WISM-1-K9 SADxxxxxxxL
Mod MAC addresses Hw Fw Sw Status
9 001e.4a6f.9be8 to 001e.4a6f.9bf7 2.2 12.2(14r)S5 12.2(33)SXI5 Ok
Mod Sub-Module Model Serial Hw Status
9 Centralized Forwarding Card WS-SVC-WISM-1-K9-D SAD1206059P 2.1 Ok
Mod Online Diag Status
9 Pass
#show wism status
Service Vlan : 192, Service IP Subnet : 172.25.1.1/255.255.255.248
WLAN
Slot Controller Service IP Management IP SW Version Status
9 1 172.25.1.2 10.8.255.240 7.0.116.0 Oper-Up
9 2 172.25.1.3 10.8.255.242 7.0.116.0 Oper-Up
WISM
6500 config
Cisco IOS Software, s72033_rp Software (s72033_rp-IPSERVICESK9_WAN-M), Version 12.2(33)SXI5, RELEASE SOFTWARE (fc2)
#sh run | inc wism
wism service-vlan 192
wism module 9 controller 1 allowed-vlan 616,796,800
wism module 9 controller 2 allowed-vlan 616,796,800
wism module 9 controller 1 native-vlan 800
wism module 9 controller 2 native-vlan 800
