IAS and 526 Controller
bob.mckinley
I'm trying to setup my 526 WLAN Controller to work with my MS IAS server. I want to be able to have my users authenicate via Radius but I can't seem to get that to work.
Under my security I added my radius server IP, and then went under my WLAN and in there I went to Layer 3, selected web policy and then under AAA I selected my IAS server. When I get connected it shows me as unauthenicated in my network connections on my laptop.
Any suggestion, thoughts?
Bob
dennischolmes
Level 7
Level 7
Did you add the shared secret to your 526? Also, did you add the 526 to you IAS as an account? If you did, do an LWAPP debug for RADIUS/IAS. It will tell you where the failure is occuring.
Scott Fella
What errors are you seeing in the logs on the WLC adn on the IAS server?
-Scott
