HI,
I'm trying to install a certificate on a 2106 to use EAP-PEAP. I don't want to use the built in cert as I suspect the 2048 key size is causing iPhone/iPad devices to fail to authenticate.
I've tried to install a seld signed cert as the vendor CA cert under security/advanced, however the cert installs but I get no prompt for the cert on clients, and also EAP-PEAP no longer works.
What are the basic steps/type of cert(s) I need to install?
SImon
