Highlighted
Beginner
Integrating Cisco Wireless 9800 with Clearpass
Dear anyone
i would like to deploy cisco wireless 9800 with clearpass, also have 802.1x authentication and Guest Web login on clearpass. Do anyone have information how to configure at cisco and aruba?
4 REPLIES 4
Highlighted
Hall of Fame Master
802.1x is the same no matter what radius server you are using. You should hit up the Aruba forum for more detail on what you need configured.
-Scott
Highlighted
VIP Mentor
Follow this guide to see how to configure it on 9800 side.
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/213919-configure-802-1x-authentication-on-catal.html
As Scott suggested, look for Aruba documentation for how to configure clearpass.
Rasika
*** Pls rate all useful responses ***
Highlighted
Beginner
Thanks all, have any idea for guest login? If i want to redirect external web authen to clearpass, how i configure on 9800?
thanks
v
Highlighted
Refer below document for webauth with 9800
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/213923-configure-a-web-authentication-ssid-on-c.html
Rasika
