cancelar
Mostrar resultados para
Pesquisar em vez de
Queria dizer:
Apresentações
Útil
Respostas
IP virtual NLB does not connect to AP
Nuno Galego
I built an NLB on windows for load balancing of the 2 wireless networks.
It turns out that if you put the IP of the radius server it works, but if you put the NLB virtual IP it can not connect ...
Is there any configuration that should do beyond the normal ??
If you configure the AP to connect to the network 172.26.1.167 it does not turn on ..
The AP is an Aironet 1200
0 RESPOSTAS 0
