01-19-2012 09:58 AM - edited 07-03-2021 09:24 PM
Hello Guys, I have an ipad that is not able to connect to a 1142 Autonomous AP. This AP was originally a light weight AP and then downgraded to autonomous.A strange thing i see is that the AP shows me only two radios. 802.11 N(2.4 GHZ) and 802.11 N(5 GHZ). I suspected the AP not to support the b/g networks. i then downloaded the most recent software but i still cannot get it to connect and on the AP's GUI i only see the above two mentionned radios. i tried to connect to two SSID's. one using WPA2 and another with open authentication and no security.but this does not work. Is it possible that some 1142 do not support b/g networks?
any help is highly appreiated.
Solved! Go to Solution.
05-31-2012 02:48 PM
Scott,
Thanks, I will double check but I believe that's what it was set to, and I have also tried both 10 and 75 per recommendations on another thread.
Brian
05-31-2012 03:01 PM
That is pretty high.... default is at 1 and usuallly can be set to 2 with no issues.
06-01-2012 12:31 PM
Scott thanks for your help. After talking with Cisco yesterday and also taking your DTIM recommentation into consideration, my radio settings are:
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 2 mode ciphers aes-ccm
encryption vlan 3 mode ciphers aes-ccm
ssid Guest
ssid Internal
antenna gain 0
mbssid
station-role root
beacon dtim-period 1
no dot11 extension aironet
Argh...any other ideas?
Brian
06-01-2012 11:34 PM
I saw sometimes problem with hidden SSIDs I didn't see in the config that you broadcast your SSID. With that command
mbssid guest-mode dtim-period 75
you broadcast your ssid, just give them a try maybe.
regards,
Sebastian
06-04-2012 07:09 AM
Thanks Sebastian. Both SSIDs for the two VLANs are broadcast.
Brian
10-31-2012 12:15 PM
Did you ever get it to work? If so what was the solution to your issue? I am having a similar issue.
11-01-2012 09:06 AM
jwinters99,
For me, my issue was the device handing out DHCP. For my network it was served out by the Watchguard, and as I wrote above, iDevices (as well as Androids and most laptops) would never get an address properly, but DID work if I set them static. So, we chalked it up to a Watchguard thing, because as soon as we yanked the DHCP role off the WG and put it on our core switch, ALL the devices started working correctly immediately.
Brian
