Is dynamic VLAN assignment supported with web-authentication?
pulsesecure
The 7.6.130.0 WLC configuration guides says this:
"Dynamic VLAN assignment is not supported for web authentication from a controller with Access Control Server (ACS)"
How should we interpret this, exactly? Does this mean that dynamic VLAN assignment is supported with web authentication from a controller if some other RADIUS server is used (Eg: FreeRadius, ISE)?
Freerk Terpstra
Level 7
Level 7
It is not supported with any kind of radius server. The radius attributes ACS uses for pushing those settings (64,65,81) are the same for every other radius implementation. Pushing a QoS profile does work.
Freerk Terpstra
Level 7
Level 7
