06-12-2021 07:27 AM - edited 07-05-2021 01:26 PM
Hi, Is there a way just to allow to access c9800 wlc via wire cable? It means we can access c9800 wlc via cable, not wireless?
Solved! Go to Solution.
06-16-2021 04:42 PM
Sorry my Bad I thought you wanted to access via console. Below is the Link to Best Practices and I also added an image with what I think is your requested answer.
Cisco Catalyst 9800 Series Configuration Best Practices:
https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9800-series-wireless-controllers/guide-c07-743627.html
Sergio Quezada
06-12-2021 02:22 PM
what is the reason, why not plug the user to Switch so he can be part of the network, why you like to go via WLC only?
06-13-2021 05:31 PM
I see 2 console ports here.
Hardware explanation video:
06-16-2021 08:55 AM
Thank you for your reply. For security, we would like to access the wlc only via wired lan, instead of wireless connection.
06-16-2021 04:42 PM
Sergio Quezada
06-17-2021 06:18 AM
Thank you Sergio!
