07-19-2017 11:16 AM - edited 07-05-2021 07:22 AM
All
i recently renewed the certificate in my ISE running version 2.0.0.306 ADE-OS version 2.3.0187, before I had renewed it it worked fine until the cert expired. I was able to get the new one in and now when a guest tries to use the Guest wireless that guest is redirected to the
https://ISE:8443/portal/gateway/sessionid=
But it says the ISE refused to connect.
I have never worked with an ISE device before, so can anyone point me in the right direction?
01-16-2019 03:29 PM
Did you try to stop and start the ISE services in the CLI?
01-16-2019 03:31 PM
I have not yet as that could be a decent amount of down time. Is there a way to restart specific parts of ISE without taking everything down?
01-16-2019 03:35 PM
01-16-2019 03:32 PM
01-18-2019 08:31 PM
The ISE application service restart resolved the problem. I believe there were two bugs involved in this situation.
CSCvj04703 and CSCut26025
After the service reboot, ISE sent a valid cert and the redirect began to work on Android devices.
Thank you
