Michal Garcarz
ISE NAC not supported with flexconnect ?
Hello Team,
vWLC 8.4.100.0
AP 2702
I have configured flexconnect (central auth, local switching and is working perfectly fine). I have a WLAN with interface putting my users in the right VLAN switched locally.
But so far i had in WLAN advanced tab NAC state = none. I wanted to enable it to support CoA, quarantine etc. It took me some time to narrow down this problem, but it's 100% replicable, after enabling NAC state = ISE NAC:
- users can authenticate (802.1x) correctly
- users get the right address via DHCP (locally switched VLAN/dhcp server)
- arp is working fine
- but i have no IP connectivity (can not even ping default gateway)
When checking in Monitor/Clients everything looks to be the same including right VLAN.
Is that expected ? Why that is happening ? Maybe after enabling ISE NAC i need to configure some ACL for flexconnect ? (but i am not doing any BYOD/NAC yet, just want basic network connectivity still at this stage).
Could you please help ?
Micha
1 ACCEPTED SOLUTION
Is the WLC up and running now?
Which version?
Upload the version 8.5.110 on the wlc and reload it. You can't do pre-download on AP as there're stuck.
After that, if APs are not registered to wlc, can you do a debug on wlc :
- debug capwap errors enable
- debug capwap detail enable
And/or if you can, access your APs in console mode and see what are the messages shown.
If you want we can also do a webex session to see what's going on. I don't have any lab available right now to test version 8.6 but sure 8.5.110 is working fine on vwlc for at least few customers (3)
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
7 REPLIES 7
Francesco Molino
VIP Mentor
Hi Michal,
The issue you're facing looks like the same we had with 8.5 and corrected in the latest 8.5 version. Can you upgrade 8.5.110?
Also the version 8.4 has been deferred.
Francesco
Hi Francesco,
I have upgraded to 8.6.101.0.
And now for 1-2 hours both APs are constantly rebooting, downloading and rebooting (changing operational status from REG to downloading). Many many times (10+). Once REG i can see most of AP specific config is lost (like static ip or flexconnect vlan support). Also primary software version for those APs is always 8.4.100.0 - so it looks like those can not be upgrade to anything newer and stays on loop :(
It does not look good :(
Would you recommend 8.6 or 8.5 ?
(i am hitting bug: CSCvf52723 on 8.4 and it's fixed in 8.6.101.0, but that 8.6 version seems to not support my 2700 even if compatibility matrix says something different)
Michal
I've not used 8.6 but I confirm 8.5.110 is working fine.
Francesco
I have definitively stuck in limbo now. WLC: Primay image 8.6, secondary 8.5. For both of them my APs are in circle trying to upgrade and failing, getting back to 8.4 (for 3 hours now). Can i keep AP on 8.4 while WLC on 8.5 ?
Is it possible that AIR-CAP2702I-E-K9 do not support newer software ?
I can not download my old relatively stable 8.4 because it's deferred. What would you recommend now ?
Michal
Which version?
Francesco
Francesco, Thank for the help here.
I have finally managed to solve it:
- downgraded to 8.0 - that software was installed on both APs without issues, but had no flexconnect mode
- after that i have upgraded WLC to 8.5 and then both APs also got upgraded to 8.5 without issues, now i have flexconnect working
- and i have achieved my initial goal - bug with ISE NAC is fixed !
Thanks again a lot !
Ok nice. You're welcome.
Francesco
Create
Recognize Your Peers
Content for Community-Ad
