ISE SNS-3415-K9 License Issue
satish Chowdary
Beginner
Beginner
 Hi All,
We are planning to take ISE SNS-3415-K9 appliance for 2500 wireless end points.
Can you please guide me how to take license?  Base lances are really required for wireless end points??
Your early response will be highly appreciated.
Satish.
Saurav Lodh
Rising star
Rising star
If you are purchasing Wireless license then Base license is not required, it would support the below services
Device onboarding/provisioning
AAA
Guest provisioning
Link encryption policies
Device profiling and feed service
Host posture
Cisco Security Group Access
Integrated vendor MDM support
Refer : http://www.cisco.com/c/en/us/products/collateral/security/identity-services-engine/guide_c07-656177.html
 Thank you Mr.Salodh.
kaaftab
Enthusiast
Enthusiast
if you have wireless only deployment you can purchase wireless license .How ever if you have mixed deployment wired and wireless then you need advance license
below find the cisco ISE license guide
http://www.cisco.com/c/en/us/td/docs/security/ise/1-2/user_guide/ise_user_guide/ise_man_license.html
***Do rate helpful posts***
Recognize Your Peers
