issue with NPS server and Bridge Groups
jkay18041
Level 3
Level 3
We have a Ubiquiti setup and an AP has started giving us trouble. Decided to put a Cisco in it's place. We currently have 2 SSID on different VLANs and 1 Management VLAN.  A Windows Server 2012 R2 Box acts as the NPS server. It has a nic on VLAN 10 and VLAN 2
After getting the Cisco setup I think my bridge groups are wrong and I was hoping someone could shed some light.
Info
VLAN2 Corp
VLAN 5 Guest
VLAN 10 Management
NPS Server VLAN10 IP 192.168.10.100
Switch port is
switch trunk encap dot1q
switchport trunk native vlan 10
switch trunk allowed vlan 2,5,10
switchport mode trunk
I can ping the AP from the NPS server via the vlan 10 interface
Here is my AP config
! Last configuration change at 03:43:44 UTC Fri Mar 1 2002
version 15.2
no service pad
service password-encryption
hostname IT_Area
logging rate-limit console 9
no logging console
enable secret 5 $
aaa new-model
aaa group server radius rad_eap
server name Server
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa group server radius rad_eap1
server name Server
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authentication login eap_methods1 group rad_eap1
aaa authorization exec default local
aaa session-id common
no ip source-route
no ip routing
no ip cef
ip admission name webauth proxy http
ip admission name webpass consent
ip domain name lcompany.corp
dot11 syslog
dot11 ssid VLAN5-GUEST
vlan 5
authentication open
authentication key-management wpa version 2
mbssid guest-mode
dot11 ssid VLAN2
vlan 2
authentication open eap eap_methods1
mbssid guest-mode
dot11 guest
eap profile PEAP
method peap
username john privilege 15 password 7
ip ssh version 2
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 2 mode ciphers aes-ccm
encryption vlan 5 mode ciphers aes-ccm
ssid VLAN5-GUEST
ssid VLAN2
antenna gain 0
mbssid
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0.2
encapsulation dot1Q 2
no ip route-cache
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 spanning-disabled
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
interface Dot11Radio0.5
encapsulation dot1Q 5
no ip route-cache
bridge-group 3
bridge-group 3 subscriber-loop-control
bridge-group 3 spanning-disabled
bridge-group 3 block-unknown-source
no bridge-group 3 source-learning
no bridge-group 3 unicast-flooding
interface Dot11Radio1
no ip address
no ip route-cache
ssid VLAN5-GUEST
ssid VLAN2
antenna gain 0
peakdetect
dfs band 3 block
mbssid
channel dfs
station-role root
bridge-group 1
interface Dot11Radio1.2
no ip route-cache
bridge-group 2
interface Dot11Radio1.5
no ip route-cache
bridge-group 3
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface GigabitEthernet0.2
no ip route-cache
bridge-group 2
interface GigabitEthernet0.5
no ip route-cache
bridge-group 3
interface GigabitEthernet0.10
encapsulation dot1Q 10 native
no ip route-cache
bridge-group 1
bridge-group 1 spanning-disabled
interface BVI1
ip address 192.168.10.210 255.255.255.0
no ip route-cache
ipv6 address dhcp
ipv6 address autoconfig
ipv6 enable
ip forward-protocol nd
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
radius server Server
address ipv4 192.168.10.100 auth-port 1812 acct-port 1813
key 7 03076F2F052D306E74203A074500052F30
bridge 1 route ip
line con 0
line vty 0 4
privilege level 15
transport input ssh
end
Any thoughts or suggestions?
Thank you!
Rasika Nayanajith
Refer below post (in my case vlan 999 is management equivalent to vlan 10 in your case)
https://mrncciew.com/2013/11/14/autonomous-ap-with-external-radius/
You need to create readio sub-interface .10 & put it to bride-group1 & make it dot1q native
Rasika
*** Pls rate all useful responses ***
Rasika Nayanajith
Rasika
added this
interface Dot11Radio1.10
no ip route-cache
bridge-group 1
interface Dot11Radio0.10
no ip route-cache
bridge-group 1
I am still not able to connect.
bridge-group 1 should be only under 0.10 sub-interfaces (G0.10, d0.10, d1.10), not under Radio0 & Radio1 interfaces.
Give it a try and see, if my previous response you will see a sample config, compare it with your one to identify differences.
Rasika
I think that's how I have it setup
no ip address
no ip route-cache
ssid VLAN5-GUEST
ssid VLAN2
antenna gain 0
mbssid
station-role root
no ip route-cache
bridge-group 2
no ip route-cache
bridge-group 3
no ip route-cache
bridge-group 1
no ip address
no ip route-cache
ssid VLAN5-GUEST
ssid VLAN2
antenna gain 0
peakdetect
dfs band 3 block
mbssid
channel dfs
station-role root
no ip route-cache
bridge-group 2
no ip route-cache
bridge-group 3
no ip route-cache
bridge-group 1
no ip address
no ip route-cache
duplex auto
speed auto
no ip route-cache
bridge-group 2
no ip route-cache
bridge-group 3
no ip route-cache
bridge-group 1
interface BVI1
no ip route-cache
ipv6 address dhcp
The AP gives me this error when I try to connect to VLAN 2 using the NPS server
*Mar 1 03:27:56.155: %DOT11-7-AUTH_FAILED: Station fcdb.b3f9.f3fe Authentication failed
