issue with upload IOS on 1310 Outdoor wifi.
tungvuxuan
Hello All,
When I uploaded IOS on the 1310, many O characters were appeared :
extracting c1310-k9w7-mx.123-7.JA3/html/level/15/ap_services_stp.shtml.gz (7017 bytes)!!
extracting c1310-k9w7-mx.123-7.JA3/html/level/15/ap_stationview-client_ltest.shtml.gz (5971 bytes)O!
extracting c1310-k9w7-mx.123-7.JA3/html/level/15/ap_system-sw_upgrade-b.htm (225 bytes)
extracting c1310-k9w7-mx.123-7.JA3/html/level/15/ap_system-sw_upgrade-b.shtml.gz (6523 bytes)!
extracting c1310-k9w7-mx.123-7.JA3/html/level/15/ap_system-sw_upgrade.htm (223 bytes)!
extracting c1310-k9w7-mx.123-7.JA3/html/level/15/ap_system-sw_upgrade.shtml.gz (6746 bytes)!
extracting c1310-k9w7-mx.123-7.JA3/html/level/15/ap_system-sw_upgrade_poll.htm (228 bytes)
extracting c1310-k9w7-mx.123-7.JA3/html/level/15/ap_system-sw_upgrade_poll.shtml (3590 bytes)!
extracting c1310-k9w7-mx.123-7.JA3/html/level/15/ap_system-sw_sysconfig.shtml.gz (7154 bytes)!!
extracting c1310-k9w7-mx.123-7.JA3/html/level/15/ap_stationview-client.shtml.gz (5898 bytes)!
extracting c1310-k9w7-mx.123-7.JA3/html/level/15/ap_contextmgr_ap.shtml.gz (4621 bytes)!
extracting c1310-k9w7-mx.123-7.JA3/html/level/15/ap_contextmgr_scm.shtml.gz (5629 bytes)!
extracting c1310-k9w7-mx.123-7.JA3/html/level/15/ap_contextmgr_scm-groups.shtml.gz (8003 bytes)!!
extracting c1310-k9w7-mx.123-7.JA3/html/level/15/ap_contextmgr_scm_summary.shtml.gz (5282 bytes)!
extracting c1310-k9w7-mx.123-7.JA3/c1310-k9w7-mx.123-7.JA3 (3600401 bytes)!!!!!!!!!!!O!!!!!!!!!!!!!!!!!!!!!!O!!!!!!!!!!!!!!!!!!!!!!!O!!!!!!!!!!!!!!!!!!!!!!O!!!!!!!!!!!!!!!!!!!!!!O!!!!!!!!!!!!!!!
!!!!!!!!O!!!!!!!!!!!!!!!!!!!!!!O!!!!!!!!!!!!!!!!!!!!!!!O!!!!!!!!!!!!!!!!!!!!!!O!!!!!!!!!!!!!!!!!!!!!!O!!!!!!!!!!!!!!!!!!!!!!!O!!!!
!!!!!!!!!!!!!!!!!!O!!!!!!!!!!!!!!!!!!!!!!!O!!!!!!!!!!!!!!!!!!!!!!O!!!!!!!!!!!!!!!!!!!!!!O!!!!!!!!!!!!!!!!!!!!!!!O!!!!!!!!!!!!!!!!!!!
!!!O!!!!!!!!!!!!!!!!!!!!!!!O!!!!!!!!!!!!!!!!!!!!!!O!!!!!!!!!!!!!!!!!!!!!!O!!!!!!!!!!!!!!!!!!!!!!!O!!!!!!!!!!!!!!!!!!!!!!O!!!!!!!!!
!!!!!!!!!!!!!!O!!!!!!!!!!!!!!!!!!!!!!O!!!!!O!!!!!!!!!!!!!!!!!!!!!!O!!!!!!!!!!!!!!!!!!!!!!!O!!!!!!!!!!!!!!!!!!!!!!O!!!!!!!!!!!!!!!!
!!!!!!O!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
extracting c1310-k9w7-mx.123-7.JA3/5501.img (131328 bytes)!O!!!!!!!!!!!!!!!!!!!!!!!O!
extracting c1310-k9w7-mx.123-7.JA3/info (274 bytes)!
extracting info.ver (274 bytes)!
[OK - 4382720 bytes]
New software image installed in flash:/c1310-k9w7-mx.123-7.JA3
Configuring system to use new image...done.
Bridge-Root#
I connected Lan cable to 1310 and used the command :
archive download-sw /overwrite tftp://x.x.x.x/...
I 've tried many version:
c1310-k9w7-tar.123-7.JA3.tar ; c1310-k9w7-tar.124-21a.JA1.
tar; c1310-k9w7-tar.123-8.JA2.tar  And the result was the same.
Is the 1310 normal when the uploading process is happended like that.
Please give me some advises.
Thank alot.
8 Replies 8
Surendra BG
This is expected!! there is no problem in that!!
Surendra
Surendra BG
Hello Surendra,
Thank for your response . I have another case, another 1310 with those notifications:
*Mar  1 00:00:03.934: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS HANGED: Interface Dot11Radio0, changed state to administratively down
*Mar  1 00:00:20.281: %SYS-5-CONFIG_I: Configured from memory by console
*Mar  1 00:00:20.284: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C1310 Software (C1310-K9W7-M), Version 12.4(3g)JA1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 19-Jul-07 23:32 by kellythw
*Mar  1 00:00:20.284: %SNMP-5-COLDSTART: SNMP agent on host Bridge-03 is undergoing a cold start
*Mar  1 00:00:20.312: %SSH-5-ENABLED: SSH 1.99 has been enabled
*Mar  1 00:00:20.316: Writing radio coredump to 'flash:/r0.rcore'
*Mar  1 00:00:20.712: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to up
*Mar  1 00:00:21.466: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar  1 00:00:21.467: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar  1 00:00:35.210: Writing radio coredump to 'flash:/r0.rcore'
Bridge-03#
*Mar  1 00:06:44.924: %SYS-5-CONFIG_I: Configured from console by console
*Mar  1 00:06:44.929: %DOT11-2-RESET_RADIO: Interface Dot11Radio0, Radio boot strap failed, Trying hardware reset on radio
*Mar  1 00:06:46.923: %SYS-3-CPUHOG: Task is running for (1994)msecs, more than (2000)msecs (0/0),process = Dot11 driver.
-Traceback= 0x2D5E4C 0x2D18D8 0x2CCE74 0x4C5548 0x76FE24 0x772B20 0x4CF2B4 0x4D755C 0x18F190
*Mar  1 00:06:48.918: %SYS-3-CPUHOG: Task is running for (3989)msecs, more than (2000)msecs (0/0),process = Dot11 driver.
-Traceback= 0x2D18DC 0x2CCE74 0x4C5564 0x76FE24 0x772B20 0x4CF2B4 0x4D755C 0x18F190
*Mar  1 00:06:50.913: %SYS-3-CPUHOG: Task is running for (5985)msecs, more than (2000)msecs (0/0),process = Dot11 driver.
-Traceback= 0x2D18F8 0x2D18E0 0x4C5564 0x76FE24 0x772B20 0x4CF2B4 0x4D755C 0x18F190
Do you know that error ? Please give me some advises.
Regards.
tung vu.
On the device that u observing tracebacks.. paste the show version..
Surendra
Surendra BG
Hello Surendra,
This is my IOS version:
ap>
ap>.033: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C1310 Software (C1310-K9W7-M), Version 12.4(21a)JA1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 16-Sep-09 18:18 by prod_rel_team
*Mar  1 00:55:44.033: %SNMP-5-COLDSTART: SNMP agent on host ap is undergoing a cold start
*Mar  1 00:55:44.984: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar  1 00:55:45.001: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
ap>
ap>
ap>
ap>
ap>
ap>
ap>
ap>
ap>
ap>
ap>
ap>
ap>
ap>
*Mar  1 00:55:55.167: %DOT11-2-RESET_RADIO: Restarting Radio interface Dot11Radio0 due to boot strap failed
*Mar  1 00:55:57.162: %SYS-3-CPUHOG: Task is running for (1994)msecs, more than (2000)msecs (0/0),process = Dot11 driver.
-Traceback= 0x2E73F0 0x2E73D0 0x4F7F20 0x7CD360 0x7D007C 0x503814 0x50CDA8 0x1A3B30
*Mar  1 00:55:59.157: %SYS-3-CPUHOG: Task is running for (3990)msecs, more than (2000)msecs (0/0),process = Dot11 driver.
-Traceback= 0x2E73D0 0x2E2680 0x4F7F3C 0x7CD360 0x7D007C 0x503814 0xen50CDA8 0x1A3B30
*Mar  1 00:56:01.152: %SYS-3-CPUHOG: Task is running for (5985)msecs, more than (2000)msecs (0/0),process = Dot11 driver.
-Traceback= 0x2E73F8 0x2E73D0 0x4F7F3C 0x7CD360 0x7D007C 0x503814 0x50CDA8 0x1A3B30
*Mar  1 00:56:02.152: %SYS-3-CPUYLD: Task ran for (6984)msecs, more than (2000)msecs (0/0),process = Dot11 driver
Password:
ap#show verv
*Mar  1 00:56:24.396: %DOT11-2-RESET_RADIO: Restarting Radio interface Dot11Radio0 due to boot strap failed
*Mar  1 00:56:26.390: %SYS-3-CPUHOG: Task is running for (1994)msecs, more than (2000)msecs (0/0),process = Dot11 driver.
-Traceback= 0x2E73D0 0x2E2680 0x4F7F20 0x7CD360 0x7D007C 0x503848 0x50CDA8 0x1A3B30
*Mar  1 00:56:28.385: %SYS-3-CPUHOG: Task is running for (3989)msecs, more than (2000)msecs (0/0),process = Dot11 driver.
-Traceback= 0x2E73D0 0x2E2680 0x4F7F3C 0x7CD360 0x7D007C 0x503848 0xer50CDA8 0x1A3B30
*Mar  1 00:56:30.381: %SYS-3-CPUHOG: Task is running for (5985)msecs, more than (2000)msecs (0/0),process = Dot11 driver.
-Traceback= 0x2E73F0 0x2E73D0 0x4F7F3C 0x7CD360 0x7D007C 0x503848 0x50CDA8 0x1A3B30
*Mar  1 00:56:31.381: %SYS-3-CPUYLD: Task ran for (6984)msecs, more than (2000)msecs (0/0),process = Dot11 driver
% Invalid input detected at '^' marker.
ap#show ver
ap#show version
ROM: Bootstrap program is C1310 boot loader
BOOTLDR: C1310 Boot Loader (C1310-BOOT-M) Version 12.3(2)JA4, RELEASE SOFTWARE (fc1)
ap uptime is 2 minutes
System image file is "flash:/c1310-k9w7-mx.124-21a.JA1/c1310-k9w7-mx.124-21a.JA1"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-BR1310G-A-K9-R   (PowerPCElvis) processor (revision A0) with 24566K/8192K bytes of memory.
Processor board ID FTX1120U0AT
PowerPCElvis CPU at 262Mhz, revision number 0x0950
Last reset from power-on
1 FastEthernet interface
1 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:1B:53:13:4D:F0
Part Number                          : 73-8960-09
PCA Assembly Number                  : 800-24963-06
PCA Revision Number                  : A0
PCB Serial Number                    : FOC11104LMY
Top Assembly Part Number             : 800-28763-01
Top Assembly Serial Number           : FTX1120U0AT
Top Revision Number                  : A0
Product/Model Number                 : AIR-BR1310G-A-K9-R
Configuration register is 0xF
ap#
I just tot of analyzing it by decoding the tracebacks.. but after seeing the software version that is...124-21a.JA1 , please upgrade ur AP to 12.4(21a)JY or the latest that we have... this will resolve what ever issue that ur facing or may face
Please dont forget to rate the usefull posts!!
Surendra
Surendra BG
Hello Surendra,
I 've uploaded 1310's IOS, but the result seem to be the same.
Bridge-Root#reload
Proceed with reload? [confirm]
*Mar  2 18:26:20.134: %SYS-5-RELOAD: Reload requested by console. Reload Reason: Reload Command.Xmodem file system is available.
flashfs[0]: 148 files, 7 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 7741440
flashfs[0]: Bytes used: 6600704
flashfs[0]: Bytes available: 1140736
flashfs[0]: flashfs fsck took 20 seconds.
Base ethernet MAC Address: 00:1b:53:13:4d:f0
Initializing ethernet port 0...
Reset ethernet port 0...
Reset done!
ethernet link up, 100 mbps, full-duplex
Ethernet port 0 initialized: link is up
Loading "flash:/c1310-k9w7-mx.124-21a.JY/c1310-k9w7-mx.124-21a.JY"...################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################
File "flash:/c1310-k9w7-mx.124-21a.JY/c1310-k9w7-mx.124-21a.JY" uncompressed and installed, entry point: 0x3000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C1310 Software (C1310-K9W7-M), Version 12.4(21a)JY, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Wed 28-Apr-10 10:31 by prod_rel_team
Proceeding with system init
Proceeding to unmask interrupts
Initializing flashfs...
flashfs[1]: 148 files, 7 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 7741440
flashfs[1]: Bytes used: 6600704
flashfs[1]: Bytes available: 1140736
flashfs[1]: flashfs fsck took 4 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
Radio0  present A506 5500 E8000000 A0000000 80000000 3
Unable to create Frequency bands, Channel / Max Power information not found
export@cisco.com.
1 802.11 Radio(s)
SSID CONFIG WARNING: [Outdoor]: If radio clients are using EAP-FAST, AUTH OPEN with EAP should also be configured.The name for the keys will be: Bridge-Root.hitek-arg-park.vn
% The key modulus size is 1024 bits
% Generating 1024 bit RSA keys, keys will be non-exportable...[OK]
Press RETURN to get started!
*Mar  1 00:00:05.382: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar  1 00:00:08.714: %DOT11-2-RESET_RADIO: Restarting Radio interface Dot11Radio0 due to boot strap failed
*Mar  1 00:00:21.074: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
*Mar  1 00:00:21.707: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Mar  1 00:00:21.714: %SYS-5-CONFIG_I: Configured from memory by console
*Mar  2 18:26:20.354: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to up
*Mar  2 18:26:20.864: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar  2 18:26:20.987: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar  2 18:26:23.704: %SYS-5-RESTART: System restarted --
*Mar  2 18:26:23.704: %SNMP-5-COLDSTART: SNMP agent on host Bridge-Root is undergoing a cold start
*Mar  2 18:26:23.727: %SSH-5-ENABLED: SSH 1.99 has been enabled
*Mar  2 18:26:35.207: %DOT11-2-RESET_RADIO: Restarting Radio interface Dot11Radio0 due to boot strap failed
*Mar  2 18:26:37.202: %SYS-3-CPUHOG: Task is running for (1995)msecs, more than (2000)msecs (0/0),process = Dot11 driver.
-Traceback= 0x2E73D8 0x2E73B0 0x4F8000 0x7CD990 0x7D077C 0x503940 0x50CF80 0x1A3B30
*Mar  2 18:26:39.198: %SYS-3-CPUHOG: Task is running for (3990)msecs, more than (2000)msecs (0/0),process = Dot11 driver.
-Traceback= 0x2E739C 0x2E2664 0x4F801C 0x7CD990 0x7D077C 0x503940 0x50CF80 0x1A3B30
*Mar  2 18:26:41.193: %SYS-3-CPUHOG: Task is running for (5985)msecs, more than (2000)msecs (0/0),process = Dot11 driver.
-Traceback= 0x2EB8A8 0x2E73A0 0x2E2664 0x4F801C 0x7CD990 0x7D077C 0x503940 0x50CF80 0x1A3B30
*Mar  2 18:26:42.192: %SYS-3-CPUYLD: Task ran for (6984)msecs, more than (2000)msecs (0/0),process = Dot11 driver
Bridge-Root>
Bridge-Root>
Bridge-Root>
Bridge-Root>
*Mar  2 18:27:04.443: %DOT11-2-RESET_RADIO: Restarting Radio interface Dot11Radio0 due to boot strap failed
*Mar  2 18:27:06.439: %SYS-3-CPUHOG: Task is running for (1995)msecs, more than (2000)msecs (0/0),process = Dot11 driver.
-Traceback= 0x2EB89C 0x2E73A8 0x2E2664 0x4F8000 0x7CD990 0x7D077C 0x503974 0x50CF80 0x1A3B30
*Mar  2 18:27:08.434: %SYS-3-CPUHOG: Task is running for (3990)msecs, more than (2000)msecs (0/0),process = Dot11 driver.
-Traceback= 0x2EB8A8 0x2E73A0 0x2E2664 0x4F801C 0x7CD990 0x7D077C 0x503974 0x50CF80 0x1A3B30
*Mar  2 18:27:10.429: %SYS-3-CPUHOG: Task is running for (5986)msecs, more than (2000)msecs (0/0),process = Dot11 driver.
-Traceback= 0x2E73C8 0x2E73B0 0x4F801C 0x7CD990 0x7D077C 0x503974 0x50CF80 0x1A3B30
*Mar  2 18:27:11.428: %SYS-3-CPUYLD: Task ran for (6984)msecs, more than (2000)msecs (0/0),process = Dot11 driver
Please open up a TAC case and we will help u out in getting the issue resolved.. If ur opening the case in APAC timezone i will pick up the case and work with u!!
Surendra
Surendra BG
Hello Surendra,
How can i open up a TAC case. Please show me.
Best Regards.
TungVu
