03-06-2013 01:15 PM - edited 07-03-2021 11:41 PM
Hi Cisco friends,
I have a running Mesh Network with AP 1552E and Controller 5508.
The end customer has a new requirement to have a indoor coverage near to AP1552E (mesh AP).
But in this building he has not any wired Network (it is far from any switched site).
The question is: We can use an AP1262 indoor with Line Of Sigth to AP1552E in the running Mesh Network?
I know AP1262 can be used in a Mesh Netwok (Root or Mesh) configuring it as BRIDGE
http://www.youtube.com/watch?v=lXi4OBkU-0U .
Thanks a lot for your answer.
Jorge Covenas
Solved! Go to Solution.
03-06-2013 01:20 PM
It will work as long as the 5ghz connection can form a link together. So you should be fine.
03-06-2013 01:20 PM
