IW3700 Design Guide
nwittenberg
Level 4
Level 4
Is there a Design Guide out for the IW3700?  I need to know outdoor distances vs. throughput.  I don't even see it in the Outdoor calculator yet.
Thanks in advance,
Nir
rmim
Level 4
Level 4
We are still working on it.  To see distance versus throughput in the mean time, please select the Cisco Aironet 3700 (AIR-CAP3702P) in the calculator instead.  The RF subsystem and PA of the IW3702 are identical to those of the AIR-CAP3702P, all other factors (antenna, RF cable) being equal, the range will be the same.  Thank you for your inquiry!
Has the design guide for the IW 3700 been completed? I would also like to see some outdoor mesh recommendations from design point of view with ap range and deployment.
