IW3702 client RSSI level of WIFI probe frames / beacons
On a Linux Host, we need to access the Signal Strength Levels of WIFI probe frames using a Cisco IW3702-4e-uxk9 firmware 15.3.(3)jd. Does the Driver natively support this, is radiotap supported? What could we do to get access to this RSSI values?
Using many IW3702 at fixed locations, we want to approximate/triangulate the location of mobile wifi handsets.
Kind regards and thank you for your help. Michael
 Using linux is quite easy to sniff wifi signal.  Take a look here:
http://www.humbug.in/2012/wireless-sniffer-on-ubuntu-linux-capture-analyze-network-traffic/
-If I helped you somehow, please, rate it as useful.-
