01-17-2014
05:02 AM
- last edited on
03-25-2019
10:21 PM
by
ciscomoderator
I have several indoor AP 3600 with mesh soft and WLC 5760.
I need to join these APs to convert to local mode but i can't.
Jan 17 15:38:00.274: *spamApTask0: 1 wcm: %LWAPP-3-RADIUS_ERR: Could not send join reply, AP authorization failed; AP:34:db:fd:43:50:90
Jan 17 15:38:00.275: *spamApTask1: 1 wcm: %CAPWAP-3-DATA_TUNNEL_DELETE_ERR2: Failed to delete CAPWAP data tunnel with interface id: 0x0 from internal database. Reason: AVL database entry not found
Indoor AP 3600 in local mode I loined to the this controller.
Thanks!
Solved! Go to Solution.
01-17-2014 07:52 AM
Configure this and try again:
aaa authorization network mac-filter local
https://supportforums.cisco.com/message/4037522#4037522
01-17-2014 05:07 AM
Hi,,
Did you add the AP MAC to your AP Policies section of the WLC? It seems like the WLC may be rejecting the AP join due to this.
Check the AP credentials on the RADIUS server, or the local MAC filtering table - if it was configured. Also check if RADIUS servers are configured and are reachable.
Security > AAA > MAC filter
or
Security>AAA>AP Polices
also paste the output of these:
WLC: sh sysinfo
AP: sh inventory
AP: sh version
Dont forget to rate helpful posts
01-17-2014 06:51 AM
Hi!
My WLC 5760 has IOS-XE 03.02.02.SE. Have wlc support local MAC filtering table ? If yes, how can i configure it?
wlc-m35-lan-1#sh inventory
NAME: "Switch 1", DESCR: "AIR-CT5760-6"
PID: AIR-CT5760 , VID: V02 , SN: FOC1742V0ZB
NAME: "Switch 1 - Power Supply B", DESCR: "Switch 1 - Power Supply B"
PID: PWR-C1-350WAC , VID: V01 , SN: AZS172203H
NAME: "TenGigabitEthernet1/0/1", DESCR: "10/100/1000BaseTX SFP"
PID: , VID: , SN: AGM162021W7
wlc-m35-lan-1#
wlc-m35-lan-1#sh ver
Cisco IOS Software, IOS-XE Software, 5700 Series Wireless LAN Controller Software (CT5760-IPSERVICESK9-M), Version 03.02.02.SE RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Fri 14-Jun-13 20:47 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2013 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.
(http://www.gnu.org/licenses/gpl-2.0.html) For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: CT5760 Boot Loader (CT5760-HBOOT-M) Version 1.0, RELEASE SOFTWARE (P)
wlc-m35-lan-1 uptime is 2 hours, 53 minutes
Uptime for this control processor is 2 hours, 54 minutes
System returned to ROM by reload at 15:54:29 UTC Fri Jan 17 2014
System image file is "flash:packages.conf"
Last reload reason: Reload command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
License Level: Ipservices
License Type: Permanent
Next reload license Level: Ipservices
cisco AIR-CT5760 (i686) processor with 10485760K bytes of physical memory.
Processor board ID FOC1742V0ZB
2 Virtual Ethernet interfaces
6 Ten Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
255000K bytes of Crash Files at crashinfo:.
3612840K bytes of Flash at flash:.
0K bytes of Dummy USB Flash at usbflash0:.
0K bytes of at webui:.
Base Ethernet MAC Address : 18:9c:5d:10:98:80
Motherboard Assembly Number : 73-14448-04
Motherboard Serial Number : FOC1741440N
Model Revision Number : A0
Model Number : AIR-CT5760
System Serial Number : FOC1742V0ZB
Switch Ports Model SW Version SW Image Mode
1 6 AIR-CT5760 03.02.02.SE ct5760-ipservicesk9 INSTALL
Configuration register is 0x201 (will be 0x102 at next reload)
wlc-m35-lan-1#
01-17-2014 07:52 AM
01-20-2014 07:29 AM
Thanks, this comment was useful and this link.
I have configured the following and it helped:
aaa new-model
aaa atothorization network default local
username [mac] mac
after that AP registered
then I configured the following
ap name [name] mode local
And this AP converted from bridge to local mode!
Thank you!
01-17-2014 07:56 AM
Mesh mode is not supported yet on 5760/3850 controllers.
if you have legacy controller then use it to convert to local mode.
on ap try, test ap mode local.
01-17-2014 07:59 AM
Good catch Saravanan +5
@Abelousov:
What deployment modes can the Cisco 5760 WLC and Cisco Catalyst 3850 support?
A. The Cisco 5760 WLC can operate in centralized mode (also known as local mode) as well as converged access mode, whereas the Cisco Catalyst 3850 operates in converged access mode. At this time, there is no support for office-extend access points, indoor or outdoor mesh, or FlexConnect access points on the Cisco 5760 WLC and Cisco Catalyst 3850.
http://www.cisco.com/en/US/prod/collateral/wireless/ps6302/ps8322/ps12598/qa_c67-726507.html
01-17-2014 09:32 AM
If this (test ap mode local) does not work, you can use the MODE button & load a Lightweigh recovery image to these 3600 APs & then connect to 5760. That should work
Below explain the mode buttone conversion process
http://mrncciew.com/2013/12/13/ap-conversion-using-mode-button/
Rasika
**** Pls rate all useful responses ****
01-17-2014 09:51 AM
including the right command.
AP#debug capwap con cli
AP#test mesh mode local
