LAP1142N-A-K9 will not join WLC2504 controller
joseph.ashley
Beginner
Beginner
I currently have six LAP1142N-A-K9 access points and just purchased an additional access point (same model) to provide coverage in an area of our building. It is connecting to a WLC2504 controller running software version 8.3.143.0 but I cannot get it to join the WLC. I can see it under "Monitor <> Statistics <> AP Join" but the status says "not joined". Additionally, it shows a base radio MAC but the ethernet MAC is all zeros. Can anyone help me solve this?
Just FYI, I know this is older equipment but I work for a small non-profit school and we don't have the budget for the latest and greatest.
Haydn Andrews
VIP Engager VIP Engager
VIP Engager
Try following from console of non working AP
capwap ap primary-base WLC1 209.165.200.225
If that doesnt work:
clear config and reload
*****Help out other by using the rating system and marking answered questions as "Answered"*****
10 Replies 10
Haydn Andrews
VIP Engager
Check out this field notice: https://www.cisco.com/c/en/us/support/docs/field-notices/639/fn63942.html
If that doesnt help can you console the AP and post the output of its boot up
Hey Haydn, thanks for replying. I already had the certificate expiration error on my other AP's and got that resolved by upgrading the software on the WLC. I figured since the software was already upgraded and the certificate issue was solved, I should just be able to connect an additional LAP and it would get the updated software pushed to it. Additionally, when I try to connect to the LAP via putty, I get a "connection refused" error. Can you advise any next steps?
Connect via console cable? If that refuses will need to factory reset via mode button and try again
Thanks Haydn. I'm actually waiting on a console cable to come in the mail from Amazon.
I tried the factory reset (I think I did it correctly) by powering off the AP, holding the mode button while plugging power back in and releasing the mode button after a few seconds.
Assuming I did a reset correctly, I still am not able to access the AP via putty or telnet and it still does not join the controller.
Also, I'm still perplexed as to why the Ethernet MAC for the AP shows (in the WLC) all zeros (in the attached screenshot)
Ethernet Mac showing as all zeros is known thing until AP joins WLC
joseph.ashley
Beginner
Beginner
Got my console cable. Below is the output from a working AP and then the non-working AP
Working AP output:
using eeprom values
WRDTR,CLKTR: 0x87000800 0x40000000
RQDC ,RFDC : 0x80000034 0x00000209
using ▒▒▒▒ ddr static values from serial eeprom
ddr init done
Running Normal Memtest...
Passed.
IOS Bootloader - Starting system.
FLASH CHIP: Numonyx P33
Checking for Over Erased blocks
Xmodem file system is available.
DDR values used from system serial eeprom.
WRDTR,CLKTR: 0x87000800, 0x40000000
RQDC, RFDC : 0x80000034, 0x00000209
PCIE0: link is up.
PCIE0: VC0 is active
PCIE1: link is up.
PCIE1: VC0 is active
PCIEx: initialization done
flashfs[0]: 37 files, 9 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 32385024
flashfs[0]: Bytes used: 11500032
flashfs[0]: Bytes available: 20884992
flashfs[0]: flashfs fsck took 22 seconds.
Reading cookie from system serial eeprom...Done
Base Ethernet MAC address: d4:8c:b5:76:1a:cd
Ethernet speed is 1000 Mb - FULL duplex
Loading "flash:/c1140-k9w8-mx.153-3.JD16/c1140-k9w8-mx.153-3.JD16"...############
File "flash:/c1140-k9w8-mx.153-3.JD16/c1140-k9w8-mx.153-3.JD16" uncompressed and installed, entry point: 0x4000
executing...
enet halted
Secondary Bootloader - Starting system.
flashfs[0]: flashfs fsck took 6 seconds.
Secondary bootloader Ethernet not enabled, skip ether_init
Boot CMD: 'boot flash:/c1140-k9w8-mx.153-3.JD16/c1140-k9w8-xx.153-3.JD16;flash:/c1140-k9w8-mx.153-3.JD16/c1140-k9w8-xx.153-3.JD16'
Loading "flash:/c1140-k9w8-mx.153-3.JD16/c1140-k9w8-xx.153-3.JD16"...#####################################
File "flash:/c1140-k9w8-mx.153-3.JD16/c1140-k9w8-xx.153-3.JD16" uncompressed and installed, entry point: 0x4000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C1140 Software (C1140-K9W8-M), Version 15.3(3)JD16, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Tue 05-Jun-18 04:14 by prod_rel_team
Initializing flashfs...
flashfs[2]: 37 files, 9 directories
flashfs[2]: 0 orphaned files, 0 orphaned directories
flashfs[2]: Total bytes: 32126976
flashfs[2]: Bytes used: 11500032
flashfs[2]: Bytes available: 20626944
flashfs[2]: flashfs fsck took 8 seconds.
flashfs[2]: Initialization complete.
flashfs[4]: 0 files, 1 directories
flashfs[4]: 0 orphaned files, 0 orphaned directories
flashfs[4]: Total bytes: 11999232
flashfs[4]: Bytes used: 1024
flashfs[4]: Bytes available: 11998208
flashfs[4]: flashfs fsck took 1 seconds.
flashfs[4]: Initialization complete....done Initializing flashfs.
Radio0 present 8363 8000 90020000 0 90030000 B
Rate table has 300 entries (16 legacy/64 11n/220 11ac)
POWER TABLE FILENAME = flash:/c1140-k9w8-mx.153-3.JD16/T2.bin
Radio1 present 8363 8000 98020000 0 98030000 0
POWER TABLE FILENAME = flash:/c1140-k9w8-mx.153-3.JD16/T5.bin
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-LAP1142N-A-K9 (PowerPC405ex) processor (revision A0) with 98294K/32768K bytes of memory.
Processor board ID FTX1628E39Z
PowerPC405ex CPU at 586Mhz, revision number 0x147E
Last reset from power-on
LWAPP image version 8.3.143.0
1 Gigabit Ethernet interface
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: D4:8C:B5:76:1A:CD
Part Number : 73-12836-05
PCB Serial Number : FOC16245PUB
Top Assembly Part Number : 800-33775-04
Top Assembly Serial Number : FTX1628E39Z
Top Revision Number : A0
Product/Model Number : AIR-LAP1142N-A-K9
% Please define a domain-name first.
Press RETURN to get started!
*Mar 1 00:00:11.955: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed (15)
*Mar 1 00:00:11.957: *** CRASH_LOG = YES
*Mar 1 00:00:13.064: %SOAP_FIPS-2-SELF_TEST_HW_SUCCESS: HW crypto FIPS self test passed (1-6)
*Mar 1 00:00:13.065: Security Core found.
*Mar 1 00:00:13.077: Registering HW DTLS
Base Ethernet MAC address: D4:8C:B5:76:1A:CD
*Mar 1 00:00:15.016: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0 (4)
*Mar 1 00:00:15.194: loading Power Tables from flash:/c1140-k9w8-mx.153-3.JD16/T2.bin. Class = A
*Mar 1 00:00:15.194: record size of 2ss: 404 read_ptr: 2660390
*Mar 1 00:00:16.055: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1 (4)
*Mar 1 00:00:16.140: loading Power Tables from flash:/c1140-k9w8-mx.153-3.JD16/T5.bin. Class = A
*Mar 1 00:00:16.141: record size of 2ss: 404 read_ptr: 2660390
*Mar 1 00:00:16.178: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar 1 00:00:17.178: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar 1 00:10:10.245: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to hostname change
*Mar 1 00:10:10.245: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to hostname change
*Mar 1 00:10:10.280: %SYS-5-RESTART: System restarted --
*Mar 1 00:10:10.280: %SNMP-5-COLDSTART: SNMP agent on host UPSCHAR-AP06-1acd is undergoing a cold start
*Mar 1 00:10:11.015: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to interface reset
*Mar 1 00:10:11.017: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar 1 00:10:11.363: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar 1 00:10:11.516: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to interface reset
*Mar 1 00:10:11.617: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar 1 00:10:11.618: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to uplwapp_crypto_init: MIC Present and Parsed Successfully
*Mar 1 00:10:18.636: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 172.x.x.x, mask 255.255.255.0, hostname UPSCHAR-AP06-1acd
*Mar 1 00:10:27.305: Currently running a Release Image
validate_sha2_block: Failed to get certificate chain
*Mar 1 00:10:27.321: Using SHA-1 signed certificate for image signing validation.%Default route without gateway, if not a point-to-point interface, may impact performance
*Mar 1 00:10:32.260: AP image integrity check PASSED
*Mar 1 00:10:32.274: Non-recovery image. PNP Not required.
*Mar 1 00:10:32.295: validate_sha2_block:No SHA2 Block present on this AP.
*Mar 1 00:10:32.334: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar 1 00:10:32.334: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar 1 00:10:42.395: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 port 0 CLI Request Triggered%No matching route to delete
Translating "CISCO-CAPWAP-CONTROLLER.domain.name"...domain server (172.x.x.x)
*Sep 30 03:38:57.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 172.20.5.5 peer_port: 5246
*Sep 30 03:38:57.438: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 172.20.5.5 peer_port: 5246
*Sep 30 03:38:57.439: %CAPWAP-5-SENDJOIN: sending Join Request to 172.20.5.5
*Sep 30 03:38:58.967: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to channel change from 0 to 1
*Sep 30 03:39:00.569: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to channel change from 0 to 36
*Sep 30 03:39:00.570: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to interface reset
*Sep 30 03:39:00.570: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to interface reset
*Sep 30 03:39:00.580: %CAPWAP-5-JOINEDCONTROLLER: AP has joined controller UPS-WLC2504
*Sep 30 03:39:00.727: %WIDS-6-ENABLED: IDS Signature is loaded and enabled
*Sep 30 03:39:01.761: %LINEPROTO-5-UPDOWN: Line protocol on Interface NVI0, changed state to up
*Sep 30 03:39:07.601: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
*Sep 30 03:39:08.629: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Sep 30 03:39:09.629: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Sep 30 03:39:09.659: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Sep 30 03:39:10.659: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Sep 30 03:40:07.921: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
Non-working AP output:
using eeprom values
WRDTR,CLKTR: 0x85000800 0x40000000
ddr init done
WRDTR,CLKTR: 0x85000800, 0x40000000
PCIE0: link is up.
PCIE1: link is up.
flashfs[0]: 56 files, 15 directories
flashfs[0]: Bytes used: 16219648
flashfs[0]: Bytes available: 16165376
flashfs[0]: flashfs fsck took 24 seconds.
Base Ethernet MAC address: 50:57:a8:4e:6d:7f
button pressed for 3 seconds
process_config_recovery: set IP address and config to default 10.0.0.1
Loading "flash:/c1140-k9w8-mx.153-3.JC2/c1140-k9w8-mx.153-3.JC2"...############
File "flash:/c1140-k9w8-mx.153-3.JC2/c1140-k9w8-mx.153-3.JC2" uncompressed and installed, entry point: 0x4000
executing...
enet halted
flashfs[0]: 55 files, 15 directories
Unable to locate IOS image with name **xx**.
Boot CMD: 'boot flash:/c1140-k9w8-mx.153-3.JC2/c1140-k9w8-xx.153-3.JC2'
Loading "flash:/c1140-k9w8-mx.153-3.JC2/c1140-k9w8-xx.153-3.JC2"...####################################
File "flash:/c1140-k9w8-mx.153-3.JC2/c1140-k9w8-xx.153-3.JC2" uncompressed and installed, entry point: 0x4000
executing...
cisco Systems, Inc.
Cisco IOS Software, C1140 Software (C1140-K9W8-M), Version 15.3(3)JC2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Mon 20-Jun-16 15:00 by prod_rel_team
flashfs[2]: 55 files, 15 directories
flashfs[2]: Bytes used: 16219648
flashfs[2]: Bytes available: 15907328
flashfs[2]: flashfs fsck took 7 seconds.
POWER TABLE FILENAME = flash:/c1140-k9w8-mx.153-3.JC2/T2.bin
POWER TABLE FILENAME = flash:/c1140-k9w8-mx.153-3.JC2/T5.bin
export@cisco.com.
cisco AIR-LAP1142N-A-K9 (PowerPC405ex) processor (revision B0) with 98294K/32768K bytes of memory.
Processor board ID FTX1611E20Z
Last reset from watchdog timer expired
LWAPP image version 8.2.111.0
2 802.11 Radios
Base ethernet MAC Address: 50:57:A8:4E:6D:7F
Part Number : 73-12836-04
PCB Serial Number : FOC16092AEU
Top Assembly Part Number : 800-33775-03
Top Assembly Serial Number : FTX1611E20Z
*Mar 1 00:00:11.061: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed (15)
*Mar 1 00:00:11.063: *** CRASH_LOG = YES
*Mar 1 00:00:12.171: %SOAP_FIPS-2-SELF_TEST_HW_SUCCESS: HW crypto FIPS self test passed (1-6)
*Mar 1 00:00:12.172: Security Core found.
*Mar 1 00:00:12.184: Registering HW DTLS
Base Ethernet MAC address: 50:57:A8:4E:6D:7F
*Mar 1 00:00:14.131: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0 (4)
*Mar 1 00:00:14.308: loading Power Tables from flash:/c1140-k9w8-mx.153-3.JC2/T2.bin. Class = A
*Mar 1 00:00:14.308: record size of 2ss: 404 read_ptr: 25A6BD8
*Mar 1 00:00:14.382: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar 1 00:00:15.170: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1 (4)
*Mar 1 00:00:15.254: loading Power Tables from flash:/c1140-k9w8-mx.153-3.JC2/T5.bin. Class = A
*Mar 1 00:00:15.254: record size of 2ss: 404 read_ptr: 25A6BD8
Failed to check if timer is initialized, NULL timer handler
*Mar 1 00:00:15.392: %LWAPP-3-CLIENTERRORLOG: Load nvram:/lwapp_ap.cfg config failed, trying backup...
*Mar 1 00:00:15.394: %LWAPP-3-CLIENTERRORLOG: Load nvram:/lwapp_ap.cfg.bak config failed...
*Mar 1 00:00:15.636: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar 1 00:14:42.333: %SYS-5-RESTART: System restarted --
*Mar 1 00:14:42.333: %SNMP-5-COLDSTART: SNMP agent on host ap is undergoing a cold start
*Mar 1 00:14:42.457: %LWAPP-3-CLIENTERRORLOG: Load nvram:/lwapp_ap.cfg config failed, trying backup...
*Mar 1 00:14:42.459: %LWAPP-3-CLIENTERRORLOG: Load nvram:/lwapp_ap.cfg.bak config failed...
*Mar 1 00:14:42.993: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar 1 00:14:43.400: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar 1 00:14:43.504: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar 1 00:14:43.705: %SSH-5-ENABLED: SSH 2.0 has been enabledlwapp_crypto_init: MIC Present and Parsed Successfully
*Mar 1 00:14:51.617: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 172.x.x.x, mask 255.255.255.0, hostname AP5057.a84e.6d7f
*Mar 1 00:14:59.496: Currently running a Release Image
*Mar 1 00:14:59.514: Using SHA-1 signed certificate for image signing validation.%Default route without gateway, if not a point-to-point interface, may impact performance
*Mar 1 00:15:04.281: AP image integrity check PASSED
*Mar 1 00:15:04.290: %LWAPP-3-CLIENTERRORLOG: Load nvram:/lwapp_ap.cfg config failed, trying backup...
*Mar 1 00:15:04.293: %LWAPP-3-CLIENTERRORLOG: Load nvram:/lwapp_ap.cfg.bak config failed...
*Mar 1 00:15:04.296: Non-recovery image. PNP Not required.
*Mar 1 00:15:04.361: validate_sha2_block:No SHA2 Block present on this AP.
*Mar 1 00:15:04.402: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar 1 00:15:04.402: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
%Error opening flash:/capwap-saved-config (No such file or directory)
%Error opening flash:/capwap-saved-config-bak (No such file or directory)
*Mar 1 00:15:14.438: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 port 0 CLI Request Triggered
*Mar 1 00:15:15.438: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 port 514 started - CLI initiated
Not in Bound state.
*Mar 1 00:20:07.817: %CAPWAP-3-DHCP_RENEW: Could not discover WLC. Either IP address is not assigned or assigned IP is wrong. Renewing DHCP IP.
*Mar 1 00:20:12.695: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 172.x.x.x, mask 255.255.255.0, hostname AP5057.a84e.6d7f
Haydn Andrews
VIP Engager
I'm trying that now. Is there a way to transfer the config file from the working ap to the non-working ap? Would that solve the problem?
AP5057.a84e.6d7f>capwap ap primary-base WLC1 209.165.200.225
% Invalid input detected at '^' marker.
put config capwap ...
if that doesnt work debug capwap console cli then try
no way to copy the working to non working, they are light weight APs all this is doing is telling it to register to that WLC. the WLC1 has to be the WLC hostname (case sensitive as well)
joseph.ashley
Beginner
Beginner
ok, so I reset the AP again, logged in, went into privilege exec (#) using "enable" command. typed capwap ap primary-base controllername ipaddress
The AP starting upgrading and is now online and joined in the WLC
Haydn.....YOUR ARE THE MAN!!!!!!!
Thanks a million bro!
Recognize Your Peers
