Looking for AIR-PCI352 antenna options
rtnelson
Has anyone used alternative antennas or upgraded to diversity on an AIR-PCI352 PCI Client LAN Adapter? I invariably find one PC with considerable tile, mortar, plaster, and wallboard (all hygroscopic) between it and the AP. Alternate antennas on the AP are not an option.
beth-martin
Level 5
Level 5
If the antenna doesn’t help, you’ll probably have to put in an access point near the device in question.
